Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
sandman83cu
May 14, 2020Aspirant
Yes, as far as I can tell this is still affecting XR routers. I have the XR700 firmware ver V1.0.1.20, the latest as far as I can tell, and running the app ver 2.5.1.10 on iOS 13.4.1. As users with the XR500, I am still getting the "Sorry, the action was failed" message. Maybe it has to do with DumaOS interfering with the app somehow? Netgear should look into it.
- mmont00May 14, 2020TutorJust FYI - if you haven't already, I would recommend opening up a chat session and letting them know. I think the more tickets they open, the faster they will respond. Hopefully!
- PhycodesMay 14, 2020AspirantSolved mine yesterday. I downgraded to two versions below the current and still wasn’t working. I then reinstalled the latest firmware and THEN did a hard reset.
I now see all devices in admin GUI and the app. Hope this helps at least one other person.- mmont00May 14, 2020TutorWould you mind listing the procedure you used to downgrade the firmware? Thanks!
