Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
Christian_R
May 29, 2020NETGEAR Employee Retired
Hello JJB651 & mmont00,
Thanks for confirming. Please factory reset your router and run through the setup assistant again.
Christian
Cyousername
Sep 01, 2020Aspirant
There really should be a "thumbs down" response for some of the moderator responses. I used to think highly of Netgear. I'm not so sure now.
- DubbbzSep 02, 2020Initiate
As this thread is one of the top google responses in the last 12 months I will reply here. This problem has been ongoing since 2018. Connected devices appear after a reset then dissapear again. I canceled my Disney Circle subscription since you can't manage your childrens devices when the router doesn't recognize thier existense. I have tried all of the solutions listed in the thread and more (downgraded firmware, factory reset, restor config, ect). My devices appear for an hour then dissapear again. Conclusion: this router is garbage. I'm going back to ASUS.
- tolson37Sep 02, 2020AspirantLove the performance of the router but the ability to edit and store device names flat doesn’t work. It’s too bad because this could be a great product w lots of kudos. Many of us like to control our kids time online.
- wldthng842Sep 16, 2020Aspirant
It's definetely a memory leak. Works great right after a reset, then stops after a few minutes/enough devices connect.
- miocevicdSep 16, 2020Guide100% agreed Dubbbz. Absolute trash router and customer support. I’ve realized that Netgear’s focus is not experienced or heavy (many devices) users. One of the other issues I had with this router is that it was assigning duplicate IP addresses to devices which was causing a number of different issues. The OS for the router is trash, settings don’t save properly, it does whatever it wants (blocks and unblocks devices when it feels like it). I scrapped the router and bought Ubiquiti (I went with the Alien model) and have had no issues since. Another thing with the Netgear I never saw speeds above 700 Mbps. When I switched to the Ubiquiti AmpliFi Alien router I immediately got 800+ Mbps. I would highly recommend switching to another router.
- MrPChuloSep 17, 2020Aspirant
The nighthawk apps update supposedly fixed this issue but it didn't for me. I am hoping with the new software coming up it will fix this issue and hopefully everything else.
