Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
RxToni
Dec 29, 2020Aspirant
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again. I can’t seem to login, reboot or check firmware updates. It won’t allow me to do anything and now I can’t access internet on my iPad. Not sure what else to do because every time I try to login, it always times out or it says error. Please I need an immediate fix, this is unacceptable. I need wifi to do my work!!!
michaelkenward
Dec 29, 2020Guru - Experienced User
Sorry, but you aren't likely to get a personalised response to a message stuck on the end of a long running discussion that has wandered all over the place. Start a new conversation with full details of your issue. It helps if you answer the questions posed in the community header.
