Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
Retired_Member
Sep 18, 2021jbclavaud, What version of nigthhawk app are you running?
I'm running 2.11.0.11 on my MK63, under Device Manager, i can see all 25 devices that connected to 2.4ghz and 5ghz.
If i tap MR60 i can see both MS1 and MS2 connected to MR60.
If i tap MR60, it shows all devices that connected to MR60, 5 devices connected to 2.4ghz and 8 devices connected to 5ghz.
Everything seems to work,
The problem is that if i tap either MS1 or MS2, there is 0 device conneted.
So far i can only depend on the Device manager to see which device is on/connected.
jbclavaud
Sep 18, 2021Tutor
My iOS app version is 2.11.6.0
I had the same issue with the previous version as well that’s why I decided to try a new account.
