mharrod
Apr 29, 2020Aspirant
Nighthawk app device manager
I have an R9000 that I use the Nighthawk app to manager. When you go to the Device Manager, it shows the same connections multiple times. Been that was for the last several app and router software/fir...
Christian_R
Apr 30, 2020NETGEAR Employee Retired
Hello mharrod,
May you try reinstalling the Nighthawk app and factory resetting the router. A successful factory reset on the router will prompt you to run through the setup assistant again.
Christian
- mharrodApr 30, 2020AspirantI’ve tried that several times. I also have two Netgear extenders which I forgot to add to the original post. I have reset them both as well.
- Christian_RMay 01, 2020NETGEAR Employee Retired
Hi mharrod,
Thanks for confirming. I'd like for our support team to reach out to you for further assistance. If you wish to be contacted, please send me a private message with your contact info.
Christian
- mharrodMay 01, 2020Aspirant
Sent.
