Derek11CH84
Jun 07, 2023Initiate
Nighthawk app device names and type in network mgr not retained
Netgear AC1900 model C7100V firmware V2.01.45 Nighthawk app 2.27.0.77 Pb: use app to create customer names for all devices and assign icons using the device manager. Two saves, one for the icon fi...
PaulGosselin
Jan 05, 2024Aspirant
Hi,
I have been ignoring this problem on my network for a while.
I followed your lead to use Access Control to (try to) change the device name.
Long story short,I removed any spaces from my new device name and replaced with "_", and it instantly worked, at least for the one that I was trying to fix.
There may also be length limitations... I'm not brave enough to try.
Thanks for the hint!!
Good Luck
Paul
PS: Now if I could get Readyshare to keep running, I'd be a happy camper. I know it is kaput when I can't even ping 192.168.0.5 (it is working today).
- michaelkenwardJan 06, 2024Guru - Experienced User
If you want help with ReadySHARE, start a new conversation in the section given over to whatever device you are using.
It would be interesting to now why you think you can get anywhere pinging that IP address.
- PaulGosselinJan 06, 2024Aspirant
Thanks for the suggestion:-)
There is a correlation between being able to ping that address and it working, that's all I was musing about.
Paul G.
