martineza79's avatar
martineza79
Nighthawk App Does Not Regognize New Firmware Update For R7000 WiFi Router
I got an email indicating the new firmware for my update is 1.0.9.64. I downloaded my Nighthawk App for Android. The Nighthawk app acknowledges my R7000 router has firmware update v1.0.9.12. When I hit the "Check for Updates" button, it indicates Firmware is up to date. Therefore, the Nighthawk App is not recognizing the new v1.0.9.64 firmware update.
  • plemans's avatar
    The apps and sometimes even the browser don't always see the most recent update.  For the most current updates, its best to go directly though the support website and manually update.  However there's been issues with the R7000 firmware as of late so if yours is running fine, I'd probabably hold off.
  • michaelkenward's avatar
    michaelkenward
    Your subject says R7000, but the footer says C7000. Which is it?
    You have no control over the firmware for the C7000.
    If it is the R7000,  is that or the R7000P?
    By the way, it may not matter, but you have posted your message in the section of this community given over to Apps and Services. (This is easily done, given Netgear's impenetrable community structure.) Your device is a Nighthawk WiFi Router.
    You might get better replies, and find other answers, over in the appropriate section:
    Nighthawk WiFi Routers
    • martineza79's avatar
      martineza79
      Great question Michael. It is the r7000. The C7000 | AC1900 is a default selection for this Netgear Community Website. I don't know why they have C7000. My Nighthawk app also identifies with my router as R7000. Either way, it is the AC1900 WiFi Router
        michaelkenward
        That's because it was posted in the "wrong section". The R7000 should be an option in the Nighthawk router zone. (It also works here.)
        Not really. R7000 is the model number. AC1900 is not a Netgear model number. It is a label that Netgear, and others, attach to hardware to describe wifi speeds. Netgear makes several AC1900 routers and devices.
        There is support material, including a manual and firmware, for the R7000 somewhere at the end of this link:
        >>>> R7000 | Product | Support | NETGEAR <<<<
        Latest firmware here:
        R7000 Firmware Version 1.0.9.64 (All Regions except China) | Answer | NETGEAR Support
        Use it at your own risk!
