WKK
Jan 16, 2025Aspirant
Nighthawk app does not support AX2700 router
My internet provider had a blackout and I had to reset my router. I tried resetting it through my Nighhawk app and it stated that it no longer supported my router and to download the Orbi app. After g...
Jan 16, 2025Guru - Experienced User
AX2700 is not a model #. What model # product are you referring too? Nighthawk or Orbi.
Nighthawk app is for all Nighthawk branded products. Orbi is only for Orbi branded products.
What mobile device are you using?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
