ValEricson
May 16, 2020Initiate
Nighthawk app doesn’t support my Nighthawk router?
Downloaded the Nighthawk app for my C7500 router. Thought I could use it like I did with Genie for my old Netgear router. The app says my router was not supported. And I thought a Netgear Nighthawk a...
May 16, 2020Guru - Experienced User
I believe the modem/router combo devices still need to go through the genie app.
ValEricson
Tried to go back to Genie, but it would not accept the default user name/password; admin/password. so I cannot use that app or the Nighthawk app.
- plemansMay 16, 2020Guru - Experienced UserYou can't use it because the password has been changed?
Or you can go through the password recovery option?
or reset it so you get back to defaults?
