g3auto
Jun 10, 2021Tutor
Nighthawk app Error CDIL-API-FAIL
I have an rax15 and am getting CDIL-API-FAIL when try to access the device manager. I am getting the error on both my iPad and iPhone. Have tried reinstalling the app and still get the error. I am on...
michaelkenward
Jun 11, 2021Guru - Experienced User
Local wifi? Anywhere Access?
g3auto wrote:
I am on the latest version of firmware V1.0.2.82_2.0.52.
What hardware is this? It may be an R7800, but who knows? I'm afraid the firmware version doesn't help, as Netgear may well use the same number for different devices.
rpmurph8300
Aug 21, 2021Apprentice
I am having the same issue with a Netgear RAX50. Running firmware 1.0.3.96 and the mobile app is version 2.11.0.11. This is the first issue i've really had with the RAX50 and the mobile app.
- DarrenMAug 26, 2021Sr. NETGEAR Moderator
I am looking into this issue and will let you know if I find a fix.
DarrenM
- rpmurph8300Aug 26, 2021ApprenticeThanks Darren. If additional info or configured settings are needed let me know.
I found out this error happens when the APP believes the router is offline does this keep happening after a reboot of the router?
