g3auto
Jun 10, 2021Tutor
Nighthawk app Error CDIL-API-FAIL
I have an rax15 and am getting CDIL-API-FAIL when try to access the device manager. I am getting the error on both my iPad and iPhone. Have tried reinstalling the app and still get the error. I am on...
rpmurph8300
Aug 21, 2021Apprentice
I am having the same issue with a Netgear RAX50. Running firmware 1.0.3.96 and the mobile app is version 2.11.0.11. This is the first issue i've really had with the RAX50 and the mobile app.
DarrenM
Aug 26, 2021Sr. NETGEAR Moderator
I am looking into this issue and will let you know if I find a fix.
DarrenM
- rpmurph8300Aug 26, 2021ApprenticeThanks Darren. If additional info or configured settings are needed let me know.
- DarrenMAug 26, 2021Sr. NETGEAR Moderator
I found out this error happens when the APP believes the router is offline does this keep happening after a reboot of the router?
Yea that appears to be the case on the RAX50 firmware V1.0.3.96_2.0.59. When i downgraded to V1.0.2.94_2.0.58 the issue doesnt appear to happen following a reboot. However, the acess control doesn't seem to be working when disabling/enabling device access from the app. Not sure if the access control issue is a nighthawk app issue or firmware issue. It's almost like the router isn't getting the command from the nighthawk app.
