Brezle
Sep 13, 2021Tutor
Nighthawk App: Firmware 1.1.6.6 - Device Map Shows No Connected Devices; Device Manager Missing Info
Details Mesh system - MR80 tri-band router - MS80 tri-band satellites (x3) - Firmware: 1.1.6.6 App - iOS (iPhone 12) v.2.11.6.0 Issue For 2 months before I updated firmware to 1.1.6.6, eve...
RJNY
Sep 19, 2021Aspirant
Can we go back the prior firmware ?
Sep 22, 2021Guru - Experienced User
- RJNYSep 22, 2021Aspirant
HI, short answer is no I have not perfomed a reset. I've alerted support and await to hear a response as others have reported the same issue. I would like a more specific insight....
- BrezleSep 22, 2021Tutor
FURRYe38 wrote:Has A reset been performed?
RJNY wrote:Can we go back the prior firmware ?
Yes I have done a reset. In the original post, I listed everything I have tried already:
- factory reset of the router and all 3 satellites (by inserting paper clip into "reset" buttons)
- reinstalling the system anew on the App, from scratch
- deleting and reinstalling the App multiple times
- logging into the App remotely via Anywhere Access (not via my wifi network)
Netgear has to be aware that 1.1.6.6 is causing issues for a lot of people -- does anyone have knowledge of a fix or one that is in progress? Thanks.
- SoCalSharkLordSep 24, 2021Aspirant
Exact same issue/NO devices found on my 2 satellites..but to add it has also affect WiFi....3 story home/seems like the WiFi is ONLY emitting from base/home unit - my 2 satellites have a gaming console plugged in to each via Ethernet cord but as I go higher in house, WiFi strength dwindles...before this firmware, I had strong signal throughout house. Help NetGear?!?
