B_Hinote
Dec 18, 2023Aspirant
Nighthawk App for Android "Your router is unreachable"
I have a Nighthawk RAX35v2 with the latest Firmware V1.0.15.128_2.0.89. I can connect to the router from all of my devices and access the internet as expected. I am also able to administer the ...
B_Hinote
Dec 19, 2023Aspirant
The modem is a Spectrum EU2251, DOCSIS 3.1 eMTA internet cable modem. Hardware version 2.76.2.
This modem was upgraded in the past 3 months to allow me to receive the 300 Mbps speed being offered by Spectrum.
If I am connecting my Cell Phone via the Router's WiFi, does the Modem still have an impact on the Nighthawk App's ability to connect to the Router? Because you have asked about it I am guessing it does and assume this is because the App is communicating over the internet back to Netgear and then coming back to the router.
Anyway, I was able to connect to the Router in the past but I cannot guarantee that I have used it since swapping out the Cable Modem..
Thank you
michaelkenward
Dec 19, 2023Guru - Experienced User
Plain cable modem with no router bit to interfere with the network.
If it is just using the router's wifi, then that should have no effect on the Nighthawk app.
The app does connect to the Internet. That is so that it can use Anywhere Access to allow you to access the router when you are away from your own wifi network.
You should be able to login to the app on the local wifi, ensure that Anywhere Access is enabled and then fill in the login details for your MyNetgear account. These are not, by the way, the same details as you use to access the router itself on the app.
