olliecans58's avatar
olliecans58
Nighthawk app for Android
I have been trying to use the nighthawk app on my S22 ULTRA phone. and it cannot connect to my netgear cable modem. and i figured out why. The app is trying to connect to the router itself not my wif...
  • michaelkenward's avatar
    michaelkenward
    Sep 21, 2023
    Do you want to try to fix this issue, or just leave us all wondering?
    Troubleshooting is painstaking process that entails knowing exactly what is happening and the kit that people are using.
