junglesim's avatar
May 09, 2022
Nighthawk app for iOS timed out. Unable to login.
Hello.  I know this is a repeat of an existing discussion that was solved (and now closed) but the solution of reconfiguring the router seemed a little extreme and who like to know whether anybody else has a solution.
The issue is I can no longer log into the Nighthawk app.  When I get to the screen that requests my admin password it returns a pop up saying 'Logon timed out, please try again. If the issue persists, try rebooting your device.'  I have tried rebooting the router several times to no avail.    It is not that I am using an incorrect password as the same credentials work to log into www.routerlogin.net.   I am using an iPhone 5s (yes very old but a phone is a phone) with the latest firmware available for it (12.5.5) and I am using version 2.13.1 of the nighthawk app, which is the latest version compatible with my iOS firmware.  I would be grateful if anyone else has any suggestions on how to fix this issue. Much thanks!
  • plemans's avatar
    Did you try disabling icloud relay? and private mac/ip address?
    We've seen a lot of reports of app issues but people still able to log in through the browser.
    If yours is working through the browser as your posts implies, i'd wait on an app update as netgear is aware of the issue (based off other posts)
