Malamute67
Sep 12, 2019Tutor
Nighthawk App for Windows 10 PC?
I just replaced my old Netgear router with a R7000. Geek Squad set it up for me. I then tried to download the Nighthawk App on my Window 10 PC, and could only find an Android and iOS version for mob...
michaelkenward
Sep 13, 2019Guru - Experienced User
Malamute67 wrote:Is there a Win 10 version that I can download, or do I just continue to use my old Genie app (it seems to be working)?
Find it here:
genie Landing Page | Apps | Discover | Home | NETGEAR
You will have to dismiss the obtrusive popup that touts the apps.
What version do you have now? Current here is 2.4.62. They aren't device specific, so the old one should be fine.
