Malamute67
Sep 12, 2019Tutor
Nighthawk App for Windows 10 PC?
I just replaced my old Netgear router with a R7000. Geek Squad set it up for me. I then tried to download the Nighthawk App on my Window 10 PC, and could only find an Android and iOS version for mob...
DiggerDon
Sep 19, 2019Initiate
Stick with the Netgear Genie - from my experience, it is far better than th nighthawk i use on my android phone. Anytime I can use the Genie, I do. Its a dirty shame that the designers don't take into consideration the level of the users and their needs. If they did, they would have incorporated new features into the Genie and re-released it for all platforms. I have Genie on all my devices in spite of having Nighthawk on some for the updating that Genie won't do.
CharlesMabe
May 28, 2020Guide
Netgear Genie literally does not work for me. Half of its functions are broken.
- michaelkenwardMay 29, 2020Guru - Experienced User
It works for most people, but without a few clues as to what is going wrong at your end, no one can suggest how you can get back in business.
