mslinker
Sep 06, 2018Initiate
Nighthawk App (formerly up)
Does anyone know if the Nighthawk App can support multiple routers in different locations? Thanks
schumaku
Sep 06, 2018Guru - Experienced User
Have just one Nighthawk App compatible router at hand.
The Remote Management view on the App does say "Updating device list" every time this section is accessed, and it seems to refresh the list of "Connect Remotely", and maintains the current online status of the device. So best guess ... I would assume it can support multiple Nighthawk routers, once added to the App while being on each local (W)LAN.
My guess is that even multiple local Nighthawk routers (ie. in AP mode) would be reachable via the "Connect Remotely" once connected.
Let's hope we get some other user or an official confirmation for this.
schumaku
A potential limitation is in place for Alexa/Google Assistant - How do I fix the "I found multiple routers linked to your account, this feature is not supported" error when sending an Alexa or Google assistant command? - appears for now only one router can be registered to the Genie cloud (again my assumption Genie cloud == Nighthawk App cloud) to make use of these...
- schumakuSep 06, 2018Guru - Experienced User
michaelkenward do you have multiple Nighthawk at hand for a try?
- mslinkerSep 06, 2018InitiateYes but 1600 miles apart. So i wont be able to test until later this fall. I will update the posting with my experience but it will be in a few months I suspect. Thank you.
- michaelkenwardSep 07, 2018Guru - Experienced User
mslinker wrote:
Yes but 1600 miles apart.Isn't that what remote access is for?
Enable that and you can also get at the distant router in the usual way. At the same time you can get at the local router. You can even use remote access to get at both routers from afar.
- michaelkenwardSep 06, 2018Guru - Experienced User
I have both an R7800 and an Rú000P registered, but I have not tried using them at the same time.
- schumakuSep 07, 2018Guru - Experienced UserMichael, Just bring up the second router using the first router LAN for the Internet connection. Perfectly sufficient for a test.
