mslinker
Sep 06, 2018Initiate
Nighthawk App (formerly up)
Does anyone know if the Nighthawk App can support multiple routers in different locations? Thanks
michaelkenward
Sep 06, 2018Guru - Experienced User
schumaku wrote:
michaelkenward do you have multiple Nighthawk at hand for a try?
I have both an R7800 and an Rú000P registered, but I have not tried using them at the same time.
schumaku
Sep 07, 2018Guru - Experienced User
Michael, Just bring up the second router using the first router LAN for the Internet connection. Perfectly sufficient for a test.
