mslinker
Sep 06, 2018Initiate
Nighthawk App (formerly up)
Does anyone know if the Nighthawk App can support multiple routers in different locations? Thanks
michaelkenward
Sep 07, 2018Guru - Experienced User
schumaku wrote:
michaelkenward wrote:
mslinker wrote:
Yes but 1600 miles apart.Isn't that what remote access is for?
Yes Michael, to link a Nighthawk router to the Nighthawk/Genie cloud to gain Nighthawk App (and Genie App) remote access you have to be local with the router, on the same (W)LAN.
Indeed. Is that supposed to add something to this conversation? Or are you just repeating what I said so that mslinker gets the message?
schumaku
Of course, backing what is already explained. Just wanted to avoid to cause confusion about remote access which unfortunately (but more securely) can't be used to link the router to the cloud.
