mal_t
Mar 04, 2019Aspirant
Nighthawk App (formerly up)
Hi, I just downloaded the Nighthawk app on my phone. Went to log in and it aks for an account. I tried logging in with my "My Netgear" account, but doesn't work. Do I need to create another account f...
michaelkenward
Mar 04, 2019Guru - Experienced User
MyNetgear now lets you into everything Netgear. In the past you could use separate credentials to get into here. I still do.
Here at least, the Nighthawk app uses the same details as MyNetgear
- schumakuMar 04, 2019Guru - Experienced User
As per the Which routers support the NETGEAR Nighthawk app? the tagged D7000|Nighthawk AC1900 VDSL/ADSL Modem Router is not supported by the Nighthawk App.
In general, the initial login - while connected to the (supported) router [W]LAN - is the router local admin account:
