MossyOakGirl014
Sep 27, 2023Follower
Nighthawk App Help
I have the Nighthawk App on my phone and accidentally disconnected my phone from the internet using the app. (I was attempting to disconnect the device above mine) Now I can't seem to get back connec...
Sep 27, 2023Guru - Experienced User
Use a different mobile device with the NH app installed there and then try to un-block your one device you accidently blocked.
