schonkeren
Dec 28, 2021Tutor
Nighthawk App "Internet Speed" test AND the web interface's QoS speedtest are NOT working at all
Firmware verson v1.0.5.38 Per title: I noticed this today both in a classic setup (Dutch T-Mobile Fibre ISP router linked to my Netgear) AND without the ISP router installed where the network cab...
- Dec 29, 2021
(sigh) the problem is not with me, nor my setup. The problem is with the app's testing functionality. No 2nd router is installed. But even with the old situation with 2 routers it should work and it doesn't.
michaelkenward
Dec 29, 2021Guru - Experienced User
schonkeren wrote:
All my clients etc. have internet, no problem. I just wanted to check the speed in my new setup without the ISP router installed. Both the Nighhawk app AND the web interface's QoS speedtest fail, in both setups. It should work though.
What is this ISP router?
If it really is a router, or a modem router, that could explain what you see.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Remember, when you are playing around with different devices on a network, you can't just unplug one thing and plug in something else. We aren't talking toasters here. You need to reboot modems and routers so that they configure themselves with the appropriate settings.
- schonkerenDec 29, 2021Tutor
- schonkerenJan 05, 2022Tutor
Still no answers? :(
