Jrochajr
May 07, 2020Aspirant
Nighthawk app IOS 13.3.1 support
When will the Nighthawk app be updated to support ios 13.3.1? The app on my iphone does not show devices in device manager while the app on my android phone shows all devices. Yes router, iphone and N...
- May 09, 2020Apple just realeased ios 13.4.1 update and Netgear also released updated Nighthawk app to deal specifically with the missing devices in device manager. Thank you. I now see devices on my iphone XR.
res1983
May 07, 2020Guide
I can't tell which post I was on but this is a know issue both IOS and Android. Netgear is aware of this. It has been this way for some time now for me on both my devices. If you use the GUI all devices will show up there.
Jrochajr
May 08, 2020Aspirant
Thanks for the info. I use device manager quite frequently to turn on and off devices. It would be quite faster to do it through the app. Thankfully I have an LG Q7+ that works with the app. However my primary phone (iphone XR) does not show the devices in the app. Yes the GUI works but it takes a while longer to go through the steps. For now I will use the LG solely for that purpose.
- JrochajrMay 09, 2020AspirantApple just realeased ios 13.4.1 update and Netgear also released updated Nighthawk app to deal specifically with the missing devices in device manager. Thank you. I now see devices on my iphone XR.
