ZoeMacUser
May 15, 2019Aspirant
Nighthawk App (iOS) Useless - Cannot Access Settings on R7000
The new Nighthawk App on iOS appears, to me, to be useless. It launches, it sees and connects to my router, but then no matter what I try to do next I get stuck with the whirling circles of endless ...
ZoeMacUser
Video would not upload.
- DexterJBMay 15, 2019NETGEAR Moderator
Hi ZoeMacUser, welcome to the community! Please try re-installing the app and check if the issue will persist. Also, doe the issue occur when using another device (another iOS or Android)? Please indicate the exact firmware version of the router.
Dexter
- ZoeMacUserMay 16, 2019Aspirant
Copy. Reinstalling the app just now made no difference in the behavior. Everything is exactly the same.
Firmware Version
V1.0.9.64_10.2.64- DexterJBMay 16, 2019NETGEAR Moderator
Hi, thanks for responding. I've sent you a message. Please check your inbox.
Dexter
