calli
May 18, 2022Guide
Nighthawk app is back to its old tricks - Logon timed out, please try again!
We can't every time a supplier messes up the firmware, throw the Router out and buy a new one!
Having said that, N...
May 18, 2022Guru - Experienced User
1. what router do you have?
2. what firmware is on it?
3. what nighthawk app version are you on?
4. are you on ios or android?
calli
May 18, 2022Guide
Re: New - R7000 Firmware Version 1.0.11.134 Released
1. Router Netgear R7000
2. Firmware Version 1.0.11.134
3. Nighthawk version 2.17.0.2193
4. Android
Apart from the Nighthawk app issue, the router firmware is also playing up as I mentioned before with all settings being disjointed.
- plemansMay 18, 2022Guru - Experienced User
did you try a factory reset? The r7000 has responded well to factory resets with firmware changes.
- calliMay 18, 2022Guide
Yes, I did. Actually, that was the first thing I did.
I must mention that I had to download the update as router did not pick up that there was an update available.
Support wanted me to do the update repeatedly before they would escalate the issue.
Then suddenly, they closed the support case.
- calliMay 19, 2022Guide
YI
I just did another update, this time with the firmware link sent to me by Support.
Disappointed to announce, that I am still getting disjointed settings which never occurred previously with previous updates.
Pity, it used to work so well previously!
I logged out from the router settings page, but still get a message from Nighthawk that Logon timed out.
