elange0721's avatar
elange0721
Follower
Sep 03, 2022
nighthawk app issues
Is anyone els having problems with the nighthawk app, I use the default password or whatever they have me use as the admin.  But the problem I'm having is that every time I enter the password in it keeps saying login timed out.  Is there any way to get it to login or is it just an app issue they need to fix?
1 Reply
  • plemans's avatar
    Are you on ios?
    If so, make sure you have icloud relay and private mac/ip address disabled. they can both cause issues with the app
