pdegan2814
May 19, 2021Tutor
Nighthawk App keeps failing at trying to disable Netgear Armor, WHAT THE THE HECK YOU GUYS
So apparently setting up my RAXE500 Router activated a trial of Netgear Armor. I don't want it. The web portal for the router doesn't have the ability to disable it. The mobile app claims to, but EVE...
gozmon
Aug 05, 2021Tutor
Yes, "You should be able to access the routers web page using a wired PC and web browser pointed at 192.168.1.1 or routerlogin.net or what ever the gateway" BUT you can not turn off "Netgear Armor" from the web UI.
michaelkenward
Aug 05, 2021Guru - Experienced User
If you are connected to the browser GUI on a mobile device, as FURRYe38 says it should enable all of the controls that you get with a wired browser.
The controls are identical here, using Chrome on an Android device with a local wifi connection. (In other words, not Anywhere Access.)
Does this mean that you can see the control but that ignores you when you try to disable the feature?
Your first message said:
I can't find a way to access fromthe Web GU
Access is is very different from control.
By the way, you seem to have hijacked someone else's conversation, which is naughty and against the rules. If you issue is not the same as the one about Armor put forward by pdegan2814 you might like to start your own conversation.
