pdegan2814
May 19, 2021Tutor
Nighthawk App keeps failing at trying to disable Netgear Armor, WHAT THE THE HECK YOU GUYS
So apparently setting up my RAXE500 Router activated a trial of Netgear Armor. I don't want it. The web portal for the router doesn't have the ability to disable it. The mobile app claims to, but EVE...
gozmon
Aug 05, 2021Tutor
Yes, "You should be able to access the routers web page using a wired PC and web browser pointed at 192.168.1.1 or routerlogin.net or what ever the gateway" BUT you can not turn off "Netgear Armor" from the web UI.
Aug 05, 2021Guru - Experienced User
I believe you have to disable Armor from the mobile app. It can't be disable from the routers UI. Once it's disabled from the app. Do a full power OFF of the router then back ON. Last resort would be to factory reset the router and setup from scratch and then dont' enable Armor.
gozmon wrote:Yes, "You should be able to access the routers web page using a wired PC and web browser pointed at 192.168.1.1 or routerlogin.net or what ever the gateway" BUT you can not turn off "Netgear Armor" from the web UI.
- michaelkenwardAug 05, 2021Guru - Experienced User
Armor is certainly there as something that I can control in the Android app.
In my case Armor is off, but it sits there trying to persuade me to enable it, along with Circle.
R7000P Remote
This is on an R7000P. You won't see those options on a router that does not support those features.
It will also not be there on an R7000P with firmware that predates the support of those features.
At least, that is how it works on one Android device. A second Android is now going through what is known in technical circles as a hissy fit as it tries to work out if it is in local or remote mode.
