ChrisM1972
Nov 02, 2020Follower
Nighthawk App keeps saying the extender setup isn't complete
Hi ... my extender is up and running having been factory reset by me due to connection issues. I reinstalled the app in order to undertake the setup but now when I go into the app it keeps saying the...
TSHECKEL
Dec 31, 2020Initiate
I'm running into the same issue. I dropped the Nighthawk app from my iphone and reinstalled but the loop of "Extender Not Set Up" keeps appearing. I cannot connect to NETGEAR_EXT as the router is up and running already.
- BadgerBadgerJan 27, 2021Initiate
Hi, has this issue been resolved? I am having the same issue with the Nighthawk IOS app. My extender has been set up successfully yet the app continues to display "Extender Not Set Up". I have closed, and reinstalled the app multiple times with no success. Please can you assist. ChrisM1972 TSHECKEL Christian_R Cswassing
- Christian_RJan 29, 2021NETGEAR Employee Retired
Hi BadgerBadger,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- TSHECKELJan 29, 2021Initiate
I believe the issue stems from the the mobile app and not the extender / router.
