ChrisM1972
Nov 02, 2020Follower
Nighthawk App keeps saying the extender setup isn't complete
Hi ... my extender is up and running having been factory reset by me due to connection issues. I reinstalled the app in order to undertake the setup but now when I go into the app it keeps saying the...
MD07
Nov 06, 2021Aspirant
1 year later from this first issue regarding the app error, and still the same error is occurring for me also. I just purchased the wifi mesh extender, successfully set it up and works perfectly. The app however is terrible and constantly tells me the extender is not set up, however it is and I’m seeing an awesome improvement on my connection all over my house.
When is Netgear/Nighthawk going to fix the iOS app issue with the extender not set up issue?
It’s a shame as now I cannot use the app and all the features on it.
HoosierITguy
Nov 11, 2021Tutor
Also have the same issue. Purchased an extender and the setup went through fine in the app, then toward the end of setup it was trying to verify that my phone was connected to the wifi but after several minutes failed.... strangely my phone IS connected to that wifi and I verified the extender is working properly.. but the app doesn't recognize that the extender is actually working/setup already. I have no idea how this stuff passes QC at Netgear lol. Might as well just ditch the app guys, it sucks.
- MD07Nov 15, 2021Aspirant
Agree! Sorry to hear you're having the same issues... I factory reset my extender and somehow it worked after a second attempt setup with the app. Hold the factory rest button-down with a pin, until it flashes 5 times. Then release and open up your wifi settings on your mobile phone and connect it directly to the extender when it appears.
From there, you can open the app again on your phone and attempt the setup again. This worked for me! It also did a firmware update when I did this. Strange how this didn't occur on my first attempt, but I'm happy it finally is working after the factory reset.
Hope this helps for you and others on this channel.
Cheers!
