MattMatt's avatar
May 14, 2019
Nighthawk App Limitations - Will it be improved to match Genie someday?
So I unfortunately allowed my phone to update the Genie app, which has now apparently been disabled by Netgear as being no longer compatible with my router.  This is, of course, complete and total bunk.  My old android phone has an older copy of Genie which works just fine.  But now I'm stuck with a dumbed down app to use with my router.
So that being said, the one feature of Genie that I sorely miss in the new app is the ability to turn on and off Access Control.  Is that going to be added back someday?  Did I miss that in the Nighthawk app?  At this point I have to go to a web browser, log in, navigate to the page, find the feature, enable/disable it, hit apply, wait for two minutes, etc. etc. etc. UGH.  Use to be a simple thing.
The Genie app had nicer icons for the various devices that are attached to my network.  This isn't really an issue but I'm wondering if there are plans to improve that part of the Nighthawk app?
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi MattMatt, welcome to the community and thank you for reaching out. You can try to use the Pause/Unpause feature on the Nighthawk app for you to disable the Internet access of a connected device. Rest assured, your feedback is very important to us and we will continue to work on improving the app for better functionality.
    Dexter
    • MattMatt's avatar
      MattMatt
      Star
      Dexter,
      Thank you for replying.  How does pausing a device that already has access to my network alloww me to disable MAC address filtering so a different unknown device can connect?
      I don't mean to sound rude, but do you know what "Access Control" is?  Just checking.  The ability to turn Access Control on and off was easily done in the Genie app.  It is nowhere to be found in the Nighthawk App.
      • schumaku's avatar
        schumaku
        Guru
        Dexter,
        This does disable the access for the device to the network - not "just" ot the Internet.
        Regardless of the previous setting, once putting a device to Pause, the access control is enabled automatically - when I have ot right other unknown devices will be allowed.
        MattMatt Turning off the Access Control would undermine the paused devices.
