MattMatt
May 14, 2019Star
Nighthawk App Limitations - Will it be improved to match Genie someday?
So I unfortunately allowed my phone to update the Genie app, which has now apparently been disabled by Netgear as being no longer compatible with my router. This is, of course, complete and total bu...
DexterJB
May 15, 2019NETGEAR Moderator
Hi MattMatt, welcome to the community and thank you for reaching out. You can try to use the Pause/Unpause feature on the Nighthawk app for you to disable the Internet access of a connected device. Rest assured, your feedback is very important to us and we will continue to work on improving the app for better functionality.
Dexter
MattMatt
May 15, 2019Star
Dexter,
Thank you for replying. How does pausing a device that already has access to my network alloww me to disable MAC address filtering so a different unknown device can connect?
I don't mean to sound rude, but do you know what "Access Control" is? Just checking. The ability to turn Access Control on and off was easily done in the Genie app. It is nowhere to be found in the Nighthawk App.
- schumakuMay 16, 2019Guru - Experienced User
Dexter,
This does disable the access for the device to the network - not "just" ot the Internet.
Regardless of the previous setting, once putting a device to Pause, the access control is enabled automatically - when I have ot right other unknown devices will be allowed.
MattMatt Turning off the Access Control would undermine the paused devices.
- MattMattMay 16, 2019Star
"Access Control" enables, or disables, the MAC Address authentication for devices on the network. If I have not added a MAC address to the router, and Access Control is enabled, it cannot use the Internet. In the Genie App, I could enable/disable "Access Control" from within the app. This feature does not appear anywhere in the Nighthawk app. I have to go through a web browser to do what I could easily do from within Genie previously, and this is annoying.
Do either of you understand this feature?? Perhaps you should read Netgear's KB on Access Control.
I never said anything about pausing a device on my network. Please ignore what Dexter wrote... I'm not trying to pause anything. :/
The control to enable/disable the Access Control (which exists in the Genie App and the Genie Program network map!) isn't available in the Nighthawk App - this is it.
Trouble is the App designers and marketeers apparently don't understand the subtile differences in the feature set, make a big mess with wording and naming of the features in the router Web UI vs the App.
The point is that disabling the Access Control would as well disable the Paused device blocking - they are mixing features, one often mistakenly defined to disable/enable the Internet access for a device, by a control named Paused/Resume ... what in fact does enable the Access Control in the background (Allow all new devices to connect), and add the device to the Access Control as a blocked device.
They are mixing what is "Access Control" with "Block" vs. "Allow" in the router Web UI with a "Device Manager" with "Pause" and "Resume".
It's a huge mess, and I din't wonder that even long term Netgear people and active community members are more than confused.
That's more a Nightmare App then anything seriously designed an integrated - I'm fully with the users complaining!
