SenperFi
Feb 21, 2024Aspirant
Nighthawk app log in
Good morning, I have spent about 3-4 hours with support attempting to log into the Nighthawk app. It is a new modem router cax80 When I log in with admin and my password (changed using my router l...
SenperFi
another interesting aspect is when the free 30 day net gear armour was activated it was checking all me devices it would send me a notification and the number of devices checked would show on the app but I could not get in the app
Feb 21, 2024Guru - Experienced User
Ya, Not sure why that's getting auto enabled. It should let you know there is a 30 day free trial on the NH app.
I'd FR and setup using a wired PC and web browser. Disable the wifi on the mobile device with NH app installed on it so there's no interference. Once the CAX80 is setup again and running good. Save off a backup configuration to file first, then try the NH app. https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router
You can disable Armor as well with in the NH app and there is one place on the CAX80 that I think can be done there as well.
