Magic_The's avatar
Magic_The
Nighthawk app login problem
Hey there, so i downloaded nighthawk app for my  android 7 smaphone,
Configured it, and it has login issue, after i entered my password, i wont be able to login second time, no matter what i did, it will always say: "Logon time out, try again. if this issues persists, try rebooting your device". After i entered my password, i wont be able to login second time, no matter what i did, it will always say: "Logon time out, try again. if this issues persists, try rebooting your device". i tried to clean the coockies and what no, wont work, nada, i dont have that issue in web login.
  • michaelkenward's avatar
    michaelkenward
    I assume that you duplicated the text of your message. It seems a bit repetitive.
    I can't see what you image is showing as a login target.
    There are three possible steps involved in getting into with the Nighthawk  app:
    • Connect to the wifi form your (unnamed) Netgear device
    • Connect to the router's controls
    The third option depends on whether you are on local wifi or using Anywhere Access.
    Each option has a different password.
    • the wifi connection
    • the router interface
    • Anywhere Access
    How do I enable or disable Anywhere Access on my router using the Nighthawk app? | Answer | NETGEAR ...
