FunTwo
Mar 03, 2021Star
Nighthawk app logon time Android app.
Android app, running the new 2.8.0.1395. Logon timeout issue. Still not getting past the admin webpage. Web browser access is fine. The error also says "try rebooting you device". Which one? Phone ...
- Mar 06, 2021
Did it, tried it on the app, didnt work.
I bite the bullet and did the factory reset, all works now.
Thanks for the help!
Christian_R
Mar 05, 2021NETGEAR Employee Retired
Hello FunTwo,
May you reboot your router and reinstall the Nighthawk app.
Christian
- FunTwoMar 05, 2021Star
Done it more than once. I dont want to factory reset the router.
- Christian_RMar 05, 2021NETGEAR Employee Retired
Hi FunTwo,
May you power cycle your router and let me know if that helps.
Christian
- FunTwoMar 06, 2021Star
