Just1080
Jan 18, 2022Tutor
Nighthawk App Logon Timed Out
Hello, I have been attempting to sign onto my Admin for the NightHawk Application, however, I am having the issue of Nighthawk Application stating, “Logon Timed Out, Please Try Again. If issue is pers...
Just1080
Jan 18, 2022Tutor
I’ve been log-in to the Nighthawk application before when I finished purchased the product in 2021. I am using iOS. I have the R7000P/Nighthawk AC2300. I don’t know how to check the firmware.
I have a Spectrum Modem, Hiltron Technologies. DOCSIS 3.1eMTA
I’ve tried resetting the router as well, and I still have the same issue.
jpeters787
Jan 26, 2022Initiate
Exact same problem, tried everything mentioned. Is there a fix???
It's no longer an option to access router settings from website, stuck without any way to do anything
- Just1080Jan 26, 2022TutorI have no fix yet. I haven’t received any help from Netgear at all. My WIFI been running slow on gaming systems and smart TVs and I think it due to my router having an update, however, no solution to fix Netgear Nighthawk App issue. Does not seem like employees at Netgear even know.
- michaelkenwardJan 26, 2022Guru - Experienced User
Just1080 wrote:
My WIFI been running slow on gaming systems and smart TVs and I think it due to my router having an update, however, no solution to fix Netgear Nighthawk App issue.Can you explain that a bit? Do you mean it has had an update or that it is waiting for one?
Whichever it is, you don't have to use the Nighthawk app to manage the thing.
A browser can do the job, be it on a PC or on you mobile device, over wire or wifi. (Wired is more reliable and safer.) Just point it at the usual login address.
- Just1080Jan 26, 2022TutorIt’s will not allow me to log into the application to figure out what the issue is. So, I am not sure if I need a update or not. I need to know how to get into the application to figure out the if my Netgear router needs a update, however, without accessing the application I cannot. No solution to fix the Logon Timed Out issue. I tried using the website through browser, however, it doesn’t show what device are connected to the router or anything other issues. Just gives you more setting to change.
jpeters787 wrote:
It's no longer an option to access router settings from website, stuck without any way to do anythingWhat does that mean? What are you doing and what happens?
Is the A7000 WiFi USB Adapter listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
