Just1080
Jan 17, 2022Tutor
Nighthawk App Logon Timed Out
Hello, I have been attempting to sign onto my Admin for the NightHawk Application, however, I am having the issue of Nighthawk Application stating, “Logon Timed Out, Please Try Again. If issue is pers...
Just1080
Jan 26, 2022Tutor
It’s will not allow me to log into the application to figure out what the issue is. So, I am not sure if I need a update or not. I need to know how to get into the application to figure out the if my Netgear router needs a update, however, without accessing the application I cannot. No solution to fix the Logon Timed Out issue. I tried using the website through browser, however, it doesn’t show what device are connected to the router or anything other issues. Just gives you more setting to change.
michaelkenward
Jan 26, 2022Guru - Experienced User
The application is just one way into the router. As I explained earlier, you can do that with a browser.
Tell us a bit more about what you did and what happened.
What is this "website". Do you mean the browser graphical user interface (GUI)? How did you try to get at it? Which address?
Terms like "will not allow" mean nothing. What are you doing and what happens when you try?
- fconverseMar 12, 2022Initiate
Was this ever resolved? I'm having the same issues now for the first time.
- michaelkenwardMar 13, 2022Guru - Experienced User
The person who first had the problem never got round to answering questions. Maybe the issue went away for them and they just abandoned the conversation.
You might do better to start afresh and with answers to the key questions. As yet we know nothing about your system, what happens and where things go wrong.
