Sund0387
May 11, 2020Guide
Nighthawk App Logon Timeout
I can not access my WiFi settings using the Nighthawk App. I get to the admin login portion and type in my password and an error message pops up saying logon timeout. I’ve tried resetting the admin...
michaelkenward
Sep 12, 2020Guru - Experienced User
lexllp wrote:
No issue with logging in from the web at 10.0.0.1 with the phone's browser.
This suggests an atypical installation.The default LAN IP address for the browser graphical user interface is 192.168.1.1.
Unless you set that up deliberately, that IP address usually happens when you put a router behind a router. (More often it is a modem.router.)
In those circumstances some things won't work as expected.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
lexllp
Sep 12, 2020Tutor
Not sure how that is relevent. The Nighthawk App was working for five months in that setup and it is not now. Yes, I set the router behind a FIOS router, which is in bridge mode. I can access the R8000P either from 10.0.0.1 or 192.168.1.2. This was the same setup on the R6900 for many years before I replaced it with the R8000P. Long stories short, I've had problems with Circle, Time Machine, etc. that led me to think that Netgear firware is not up to par. Users shouldn't have to search for tricks and obscure routines to fix some hidden issues on a router that ought to be a plug and play for simple wi-fi setups.
