Sund0387
May 11, 2020Guide
Nighthawk App Logon Timeout
I can not access my WiFi settings using the Nighthawk App. I get to the admin login portion and type in my password and an error message pops up saying logon timeout. I’ve tried resetting the admin...
thesuncard
May 06, 2021Initiate
I've found the solution. I guess after any update or reboot on the router it seems to to change the time zone. Fix your appropriate time zone on routers settings directly from the web. Should be under Administration > NTP settings > Time Zone.
Apply let it reboot. Try your app again. Your welcome.
