Sund0387
May 11, 2020Guide
Nighthawk App Logon Timeout
I can not access my WiFi settings using the Nighthawk App. I get to the admin login portion and type in my password and an error message pops up saying logon timeout. I’ve tried resetting the admin...
Iggy1
Nov 27, 2021Aspirant
My app does the same thing. I just bought a new nighthawk router and it took forever to setup I assume it’s because of the app issue ?
- JonManNov 27, 2021AspirantIn my case, after a firmware update the time zone was reset so once you set your time zone to the correct one, The logon timeout won't reoccur
You'll have to reset the time zone using the Web Interface not the app - michaelkenwardNov 28, 2021Guru - Experienced User
Iggy1 wrote:
I just bought a new nighthawk router ....Which one?
...it took forever to setup I assume it’s because of the app issue ?Maybe, but without knowing much more it is anybody's guess as to what happened.
So many unknowns.The modem? Which app? Etc.
