Sund0387
May 11, 2020Guide
Nighthawk App Logon Timeout
I can not access my WiFi settings using the Nighthawk App. I get to the admin login portion and type in my password and an error message pops up saying logon timeout. I’ve tried resetting the admin...
Macmac312
Apr 29, 2022Aspirant
You have to use routerlogon.com From a laptop. Yeah once you connect to your router through thru netgear then then look up at the top you will see it updates available. Once you click that and update your router you will be able to log into nighthawk
