Sund0387
May 11, 2020Guide
Nighthawk App Logon Timeout
I can not access my WiFi settings using the Nighthawk App. I get to the admin login portion and type in my password and an error message pops up saying logon timeout. I’ve tried resetting the admin...
Aru92
Nov 06, 2022Aspirant
I am also having the same issue from the Nighthawk app after router firmware update but I can enter through browser...what shall I do now??
- michaelkenwardNov 06, 2022Guru - Experienced User
Aru92 wrote:
I am also having the same issue from the Nighthawk app after router firmware update but I can enter through browser...what shall I do now??It isn't obvious that this has anything to do with firmware.
If that was the cause then people would have successfully rolled back to restore this function. That doesn't seem to work.
Have you tried it?
The same issue also hits routers with unchanged firmware. The consensus is that it is the app that is bust.
