RonProgres
Sep 13, 2022Aspirant
Nighthawk App Network Map
On the Nighthawk Network Map, it only seems to show the router (R6400V2) and the extender (Ex6250), but not any of the other connected devices. The router has a green dot next to it, but the extende...
Sep 13, 2022Guru - Experienced User
Try logging in through the browser. You can see all the connected devices on there.
- RonProgresSep 14, 2022Aspirant
Login to what? I can login to my router and can see the devices connected from my laptop. What I cannot see is the ex6250 extender. Is it possible to see what devices are using the Router and what are using the ex6250? On the nighthawk what does the white dot signify on the network map? Thanks.
