jmer
Apr 03, 2021Aspirant
Nighthawk app no auto log out
I've been using the Nighthawk app on an iPhone 7 ios 14.4.2. No problems with logging into the router or using the app. However, I have to manually logoff through the app menu in order to logoff the ...
jmer
Apr 04, 2021Aspirant
I think I figured out the problem. It has to do with the "Remind Me" button and iPhone TouchID. It appears that the TouchID is saving the "Remind Me" setting, thus if this is set by the TouchID and I scan my finger, the app stays logged in when closed. If I cancel the initial TouchID login, turn off the "Remind Me" button and then login using either the username or TouchID then closing the app will log off automatically when closing the app. I just can't figure how to reset the TouchID settings for the app. Any ideas where to turn off TouchID for login?
KatyAnn
May 18, 2021Aspirant
I was having the exact issues with the logout not showing up. I have FaceID on my iphone XR and it was automatically logging me in. I had to uncheck the Remember Me box to get the logout to show back up. To turn off FaceID, I went to my phone settings and toggled it off for the Netgear app. You probably have the same thing for TouchID where you can toggle off the app in your phone settings.
