Gabe019
Dec 30, 2020Aspirant
Nighthawk App no longer functioning
Hi, I received an email last week from Netgear Security that new firmware was available, however, the Nighthawk app on my IPhone keeps saying that it either cannot find the router or that WiFi is n...
- Jan 10, 2021
I'm glad it worked. For what it's worth I made a comment about the app issue which still doesn't work for me and got an email from support. I made it clear they wouldn't have remote access in my response. Haven't heard back in two weeks now. You might want to run a security scan if you gave them access.
Gabe019
Dec 31, 2020Aspirant
Thank you for your reply Ralac71
Part of my problem is that I cannot access the router from my laptop (either by using the IP address given or via routerlogin.net). I follow the instructions to download the update but here's the message:
This site can’t be reached
192.168.1.1 took too long to respond.
Is there anyway to get around this?
I'm not tech savvy but I was able to download updates in the past without much difficulty.
Thanks again.
Christian_R
Jan 05, 2021NETGEAR Employee Retired
Hello Gabe019,
You may want to try a factory reset on the router and run through the setup assistant again using the Nighthawk app.
Christian
