Jennobeans
Jan 09, 2020Aspirant
Nighthawk App not allowing devices to be paused and shows 80 something not connected devices.
For the last 2 weeks my router has been showing anywhere from 40 to 90 devices on my screen but say not connected. This shows on the Netgear computer screen and on the NightHawk app. It also shows ...
Superdan186
Jan 13, 2020Tutor
I have the same problems and also my brother Nighthawk AX8 same problems.
Anyone got it fix?
DexterJB
Jan 14, 2020NETGEAR Moderator
Hi Jennobeans and Superdan186, may I know what steps you've tried so far? Are the listed devices your devices that are currently connected to the network and show up on the web UI (routerlogin.com) as well?
Dexter
- Superdan186Jan 14, 2020Tutor
I think I know why maybe because the router is in AP mode. I have not try to disable AP mode see if it work.
- DexterJBJan 15, 2020NETGEAR Moderator
Hi Superdan186, thanks for responding. Yes, some router functions will be disabled when the device is on AP mode. More on that on the link below.
http://kb.netgear.com/app/answers/detail/a_id/30299
Dexter
- HasselMar 26, 2020Aspirant
We are having the same issue AFTER the latest firmware update!
