MartinDrew71
Jun 10, 2019Aspirant
Nighthawk App not compatible
I've just setup my Nighthawk D7000v2 (including registering for a Netgear account) but the Nighthawk App is stating my router is not compatible with the App. Any Suggestions/Advice kind regards M...
MartinDrew71
Jun 11, 2019Aspirant
I have firmware: V1.0.0.41_1.0.1
if I click on update I get the message I have the latest version
michaelkenward
Jun 11, 2019Guru - Experienced User
That guarantees nothing.
It usually works, but there can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
The only way to check is to visit the support pages for your device.
If this really is the D7000v2 listed in your message, it is not the latest.
Indeed, there is no version with that number for the D7000v2 or for the D7000v1.
D7000 | Product | Support | NETGEAR
D7000v2 | Product | Support | NETGEAR
