Rellek7
Jun 23, 2022Aspirant
Nighthawk app not connecting
I have an EX6100v2 extender and I can no longer connect it to my router through my iPhone. I continually get the "Unable to connect to router" message. There are 2 devices operating through the exte...
Jun 23, 2022Guru - Experienced User
I'm a little confused. You put there's 2 things operating through it but that you're unable to connect to it?
Just would like to clarify that a little.
Also, what router are you connecting it to?
did you set it up using wps or using the installation assistant (through the browser)
- Rellek7Jun 23, 2022Aspirant
I set up the extender through the Nighthawk app. While the 2 devices I needed the extender for are connected through to the internet, I am unable to get the extender to connect to my router (FiOS Gateway).
- plemansJun 24, 2022Guru - Experienced User
What fios gateway? some have they're own built in mesh function. I think its called self organizing network (son).
If yours has that, disable it.
