DannyC1983
Nov 01, 2022Aspirant
Nighthawk App not logging in on local connection
Can't login to any of my Routers/Extenders using the nighthawk app, basically just says logon timed out tells me to reboot, after looking at the app reviews am not the only one đ any help would be gr...
michaelkenward
Nov 01, 2022Guru - Experienced User
DannyC1983 wrote:
Can't login to any of my Routers/Extenders using the nighthawk app, basically just says logon timed out tells me to reboot, after looking at the app reviews am not the only one đ any help would be great đ
And what are these Routers/Extenders?
And what is this Nighthawk app? Android? iOS?
Then there is the modem/gateway/ONT that connects these things to the Internet. What is it? Make and model?
Has this just started happening? Is this a new setup?
Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
- DannyC1983Nov 01, 2022AspirantRouter: Nighthawk Rax120 AX6000, FWV: 1.2.8.40
Extender: Nighthawk X6 AC2200, FWV: Not updated as yet can't install.
Modem: Virgin Hub 3.0, 500mb Speed
Nighthawk App: Android: FWV: 2.20.3.2515- michaelkenwardNov 01, 2022Guru - Experienced User
Nighthawk App: Android: FWV: 2.20.3.2515The Extender is not a Netgear model number that I recognise. An extender would be something like EX7700.
Virgin provides modem/routers. How is your Virgin Hub 3.0, a somewhat aged model, configured? As a modem/router or in bridge (modem only) mode.
How is the Rax120 set up? Router or Access Point mode?
